L.Dix
typing "C" in dimensions
I commonly switch between metric and imperial when drawing dimensions, however recently when typing the "C" for "cm", only the m appears.
I'm sure I've accidentally disabled something!
For example, If I am in an imperial setup, and go to type in 10cm, it normally converts it to 3.937", however now it misses the "C" so I would type in 10m, and it would end up being 32'9.701"
Watch very carefully and see if you are seeing cm and then it is changing to just m.  If so, check your autocorrect settings (probably system wide). If you add your operating system and VW version to your forum signature (click on your name at the upper right), we can offer more explicit suggestion.
