- 0
VW itself takes 15min to launch if workgroup file is on VPN
Asked by
Ben Jameson
Asked by
Ben Jameson
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
We’re now working from home and having VW issues related to the workgroup folder. We’re using a split tunnel VPN that uses our local wifi for everything, except connecting to our office server which uses the office internet. File transfer to the server over internet is still relatively fast (over 20mbps).
The issue we’re having is VW takes 15min to open without any project, and once open nearly every project file will crash VW.
The temporary solution has been to remove the workgroup file link, and then VW opens in less than a minute and opens files normally.
We heavily use the workgroup folder to coordinate resources between projects so this is only a temporary solution for us.
Please could you help.
Thank you
