HSP DanS
VW 2020 Crashing when referencing
Having problems when trying to update a reference in one of our files - every time we try to update VW crashes.
Any Ideas?
1 answer to this question
Here's some logical actions that might reveal where the issue lies:
Try something easy first:
  • Remove the reference then re-add it. - This process might reveal that other conditions are the problem, like the file being referenced may have been moved or corrupted (for example).
  • Check that you can open the file that is being referenced.
To determine if your installation is the issue:
  • Determine if this issue occurs for other users/on different computers, using the same file.
    • If other users experience the same crashes, then the issue is likely with either your file or the referenced file.
  • OR
  • Perform an acid test:
    1. Go: File > New… > Create blank document > draw some random stuff, save, then close.
    2. Go: File > New… > Create blank document > reference the other new file, save, then close.
    3. Open the referenced file and make some changes, save, then close.
    4. Open the referencing file, try updating the reference.
    • If this works file, it suggests the issue is with your file or the referenced file. Restore from a backup.
  • Repair your installation of Vectorworks (version 2019 and later)
    1. Open Vectorworks 20XX Updater application
      • On Mac this is here: Macintosh HD > Applications > Vectorworks 20XX
      • On Win this is here: C:\Program Files\Vectorworks 20XX\Vectorworks 20XX Updater\
    2. In the 'Advanced' menu, choose 'Repair.'
    3. Re-test for the issue.
