ScottLebsack 41 Posted August 5, 2020 I cannot do a viewport override on landscape areas, to have them show up with color in one viewport and grayscale in all others? Quote Share this post Link to post
0 Pat Stanford 1,443 Posted August 5, 2020 Viewport Overrides only work with objects that are set to use Class Attributes. I don't know is landscape areas can be set to use Class Attributes or not. If they can, then you should be able to use overrides. Quote Share this post Link to post
0 ScottLebsack 41 Posted August 6, 2020 I can set them to use class attributes, but couldn't get an override to work. Quote Share this post Link to post
0 Pat Stanford 1,443 Posted August 7, 2020 Can you post a small sample file? Quote Share this post Link to post
0 CipesDesign 148 Posted August 7, 2020 Note that in order for VP Class Overrides to work, USE AT CREATION must be ON in the Class setup dialog. 1 Quote Share this post Link to post
0 Andy Broomell 1,028 Posted August 7, 2020 2 hours ago, CipesDesign said: Note that in order for VP Class Overrides to work, USE AT CREATION must be ON in the Class setup dialog. Is that something specifically for Landscape Areas? Otherwise that's not true generally... Quote Share this post Link to post
0 CipesDesign 148 Posted August 7, 2020 Unless I am mistaken, that is a general rule about Classes, and VP Overrides. Quote Share this post Link to post
0 Katarina Ollikainen 15 Posted August 16, 2020 Hi Scott, I don't know if you're still looking into this one. I would suggest that you're using Data Visualisation instead of viewport override. Attached is a screenshot of two landscape areas in three different viewports. The first one is without any DV, in the second one I've asked it to look at the individual names in the Landscape areas and coloured them different grey according to this. In the third one I've done the same thing but asked it to use hatches instead. Of course you can choose anything you want as the parameters, this is just an example. You have a much bigger scope with Data Visualisation - and from 2020 you can use it in design layers as well, not just viewports (I often use it for planting schemes where I want to see (while I'm working) how much of the planting is deciduous and how much is evergreen). Quote Share this post Link to post
0 Andy Broomell 1,028 Posted August 16, 2020 On 8/7/2020 at 1:04 PM, CipesDesign said: Unless I am mistaken, that is a general rule about Classes, and VP Overrides. "Use at Creation" is not necessary for Viewport class overrides to work. As long as an object's attributes are set to "By Class" then overrides will work. (Use at Creation can be helpful in making sure attributes are set By Class when you make objects, but it doesn't directly affect whether or not overrides work.) 1 Quote Share this post Link to post
0 Pat Stanford 1,443 Posted August 16, 2020 I just tested. I believe Andy is correct. That was my understanding before. Use At Creation allows you to have objects created in that class use the Graphics Attributes, Text Styles, and Textures of the Class regardless of what the settings in the Attributes Palette are. It has no impact on anything other than objects created while that specific Class is active. Quote Share this post Link to post
0 ScottLebsack 41 Posted August 17, 2020 @Katarina Ollikainen good approach. I find I'm using visualizations for more things recently. I hadn't thought about landscape areas, but I'll take a look. Quote Share this post Link to post
