richard2020 Posted August 3, 2020 Share Posted August 3, 2020 Hi there, I'm trying to show the walls with brick below half height, above that a horizontal board rail and vertical board above with a thick coping overhanging at the top. I'm guessing this is a wall stye amend but is it just a case of stacking components on top of each other on the same plane? The finish output is just 2d line and infill no colour. Any suggestions on how to do this please? Thanks Quote Link to comment
CipesDesign Posted August 3, 2020 Share Posted August 3, 2020 I usually use two walls for this condition. (Note: this is also how these sorts of things are generally built in my neighborhood: first we build the structural wall then we apply the brick facade to the lower exterior portion.) Quote Link to comment
Jeff Prince Posted August 3, 2020 Share Posted August 3, 2020 @richard2020 Vectorworks doesn't do stacked walls, you have to fake it with the tool of your choice. If you are just drawing in 2D, this should be easy. If you are doing it in 3D, it's a little more work. Quote Link to comment
