Irrigation Outlet - Problem with Symbol Rotation
loretta.at.large
I'm working on an irrigation plan and decided to make a new symbol to use for an irrigation Outlet because I wanted the graphic to have a different color.  It seemed to work at first, but when I rotate the direction of the spray, the symbol doesn't rotate with it like it does with my other irrigation outlet objects.  All I did was duplicate one of the existing outlet symbols I had in the Resource Manager, changed the color, and gave it a different name.... but it just won't rotate!  I also have "Toward Coverage" selected where it says "Symbol Rotation" in the Object Info Palette on all the outlets.  Attached are a couple images for clarity.  It's a little cluttered, but you can see that the burgundy, black, and dark blue symbols point in the same direction as the coverage, whereas the light blue symbols do not rotate with the coverage direction.  Am I doing something wrong?  Or is this a bug in the program?
0 answers to this question
There have been no answers to this question yet
