KarynT
Can't select object in rotated view
I've been working on this file for a while & recently have lost the ability to select objects in rotated view. It's a pain to not draw dimensions when the project is aligned horizontally/vertically. My mouse goes to select an object the actual selection point is offset & not where I'm clicking on the screen. I had this problem with another file, but was able to knock it back by switching from Top/Plan to Top & back again. Not for this one though.
If I change the rotation it reverts back to the angle of the original layout. Do I have conflicts with an origin point? Does it matter if some objects are on a screen plane & others the layer plane? I've no idea how that got noodled up. Force select on an object where I 'think' it should be results in the message that there isn't anything there.
Unified view is selected with the options selected in all the boxes.
3 answers to this question
Suggestion 1) Check to make sure that your Class Options are set to Show/Snap/MODIFY others.
Suggestion 2) Quit VW's. Restart your computer. Restart VW's.
@CipesDesign,
Suggestion 1 is valid & yes the classes were set to S/S/M others
Suggestion 2 - did that & decided to use a different version of the file.
I should have mentioned that I'm using 2020 SP4 on a MacBook Pro running current version of Catalina.
Thank you for the quick response!
Karyn
Hi @KarynT, the peculiarity and temporality of the symptoms you describe, could very well be one of the very many caused by what I call, 'far out objects.' I've encountered this so many times I've created a script to help users diagnose and rectify this condition in their files. Although using an older/backup file has helped, there may still compromising conditions so worth running through the diagnosis stage at least.
See here:
