Nicola Bird
How to modify holes created in slabs when stairs change
Hi,
I'm a newbie to Vectorworks and I need to modify a hole I created in a slab as my stairs have moved to the right and i cant seem to find any information on how to do this? Please see images uploaded.
In the edit boundary on the right picture I cant access the boundary where the original  stair was cut what are the steps to do this please?
Thanks Nicola
image.thumb.png.e78cdd70c5d487cc933e4cafd6ba8529.pngimage.thumb.png.db268edba25c4c638f72da0f4f4702e2.png
3 answers to this question
Clip Surface and Add Surface can be used with Spaces. Draw polygons for the areas you need to remove select them and the Space and Clip Surface. Draw polygons for the areas you need to add. Select them and the Space and Add Surface.
Double-click on the slab -> in the Edit Slab pop up window select Modifiers, then OK -> move/edit the shape you used to modify the slab -> click Exit Modifiers (top right corner).
