Sebasrougs
MOVE extrude geometry in a series of points
Hi everyone, i have a problem when i try to MOVE  an extrude geomertry in the z axis to make a SERIES of  copies at a certain distance , it didnt work the way i w ant. it makes copies sequenly of each object but no of all objects at once in a series. i want to achive something like the last picture. Thanks!.
Not reading the nodes, but just looking at the result, it looks like you are selecting everything, moving the object, deselecting the first object, moving again, repeat.
If I was doing this in Vectorscript I would probably group everything, make and move the duplicates and then ungroup everything if it needs to be separate.
HTH
@Pat Stanford I tried to group everything but it didnt work. i am still trying to figure it out  what could be, i am new using marionette,so i dont know how all the nodes works, but thanks for your comment.
@Sebasrougs when you create your list of points to move your duplicates, you need to use the Mix2 node and select the Cross Reference mode in the dropdown. You need to create XYZ coordinates of every possible combination.
