Ron Prochot 0 Posted July 19, 2020 I managed to install Vectorworks Architect (VW) 2016 on my Retina 5K, 27" (2014) iMac but the application crashes on launch with an error message saying Apple will be notified. The application window opens, my license info etc. displays and then I get the error message, "Vectorworks 2016 quit unexpectedly. Click Reopen to open the application again. ..." The VW application is located in a folder, in the application folder, rather then having it installed the Vectorworks Application directly into the OS Application folder. Could that be the source of the problem? Thanks for any assistance you may be able to provide. Quote Share this post Link to post
Mark Mosher 2 Posted July 20, 2020 Hi Ron, Others may have something to add in here, but I have read where only VW 2019 and up is officially supported on Catalina. Even though I hear of some having gotten earlier versions of VW to work on Catalina [not tried by myself]. HTH Quote Share this post Link to post
rDesign 479 Posted July 20, 2020 Mark is correct: See the following link for info on Vw OS Compatibility. According to that page, the most recent version of macOS compatible with Vw 2016 is Sierra 10.12. Quote Share this post Link to post
altoids 1 Posted August 7, 2020 Well, there are a couple of strange things here. Strange 1: I find that VW15 has run on every OSX from 10.11 through 10.15 without any major problems. 10.15 broke VW16 which wont even launch. This perhaps suggests that it is not the Mac's OS that is causing the problem as older versions of VW work. Strange 2: The compatibility chart claims that VW is only supported for ~ 1 year on the MAC platform. From the Chart VW16 is only supported through Mac OS 10.12 (which Apple released in Fall 2016), VW17 is only supported through Mac OS 10.13 (which Apple released in Fall 2017), VW 18 is only supported through Mac OS 10.14, (which Apple released in Fall 2018), etc. This implies that there is only about a year's life in each release, which is surprising to say the least. Quote Share this post Link to post
Ron Prochot 0 Posted August 8, 2020 Thank you gentlemen for this information. I am currently running VW 16 on my 2008 iMac running OSX 10.10.5, while my 2014 iMac running OSX 10.15.6 with about 4 times the cranking power has to sit idly by because it can't run the application under the current OS, even though the 2008 iMac is straining under the load when to comes to rendering, or even when trying to boot the program. I suppose I could re-install the old OS (10.12.12) into the 2014 iMac, but then I'd be out of Sync with Apple's updates AND I understand (and experienced) that that particular OS was rather 'buggy'. So for now, I will leave it as is, and hammer on with VW 2016 on the 2008 iMac, running OSX 10.10. It's exasperating because it's a waste of the cost of new iMac and the VW 2016 application, since VW 2014 and 2015 will seem to run better on the 2008 iMac than does VW 2016, Once again, THANKS for shining some light on this issue. PERHAPS I will look at installing VW 15 onto the 2014 iMac. It may give phenomenal results (???) MMMMmmmm? Thanks again! Quote Share this post Link to post
altoids 1 Posted August 16, 2020 VW15 is not perfect and problem free running under Mac OS 10.15, at least it works. Apple gives developers years of warning before dropping a feature from software, so the lack of support cannot be only due to Apple. Perhaps VW is just being cautious, but it is difficult to understand how they could drop support for each of their last 5 releases within12 months of each release. My toaster has a longer service life. 1 Quote Share this post Link to post
Ron Prochot 0 Posted August 17, 2020 Thanks for the update Altoids. I think I'm beginning to understand why some of my fellow designers, who originally got me into using VW, have shifted away from VW and the Mac platform. For now I'll plug along with the old iMac for a little while longer. Thanks for your information. Quote Share this post Link to post
