jimi123 Posted July 16, 2020 Share Posted July 16, 2020 I create a data tag - chair. How do I export the table chair in the report? Quote Link to comment
Pat Stanford Posted July 16, 2020 Share Posted July 16, 2020 By Table, I think you actually mean a VW Worksheet. If you have the data for the tag stored in a Record.Field attached to the chair then just go to the Resource Manage and create a new Worksheet. Right click in a Row Header (I usually start with Row 3 so I have rooms for titles above). and choose Create Report. In the Criteria section at the top set it to be objects that have the record attached. In the bottom select the fields you want to display. After you get the worksheet showing the information you want, go to the Worksheet File menu and make sure there is a check next to the Worksheet On Drawing option. Move the worksheet where you want it to display in your drawing. HTH. Ask again if this is not clear enough. 1 Quote Link to comment
