Reshape Tool Multiple Vertices
I have this half moon shape and I want to simultaneously adjust these two vertices:
If I use the marquee select tool within the Reshape tool:
After selection, the vertices disappear and I'm not selecting anything:
If I also marquee around the vertex in the middle:
So it seems you can only select multiple vertices that are adjoining. Is that the correct thinking?
