CipesDesign Posted January 26, 2006 Share Posted January 26, 2006 Nudge increments are based on pixel size/screen res. As you zoom out, the actual nudged distance will increase. Quote Link to comment
Ray Libby Posted January 26, 2006 Share Posted January 26, 2006 Ctrl + Shift will nudge by your snap grid setting. Quote Link to comment
Drake Posted January 26, 2006 Share Posted January 26, 2006 Dang Ray, you are a wealth of info! Quote Link to comment
Jonathan Pickup Posted January 26, 2006 Share Posted January 26, 2006 and on a Macintosh Apple+shift will nudge to your grid snap settings. Change the grid snap settings by double clicking on the grid snap constraint Quote Link to comment
MPJDesign Posted January 26, 2006 Author Share Posted January 26, 2006 Awsome...thanks all Quote Link to comment
MPJDesign Posted January 27, 2006 Author Share Posted January 27, 2006 Is there a way to redefine the distance of travel for the Nudge feature? 1 Quote Link to comment
CJohnson Posted February 6, 2006 Share Posted February 6, 2006 All of the above are great; however there really should be a nudge feature independent of the grid. As a former powercadd user, thats a feature that I really miss. Quote Link to comment
jan15 Posted February 6, 2006 Share Posted February 6, 2006 quote: Originally posted by CJohnson: A...there really should be a nudge feature independent of the grid... "Nudge" IS independent of the grid. You're talking about "Move Objects on Grid". Open VectorWorks preferences to see and change the type of arrow key that controls each of those. Quote Link to comment
ionw Posted February 6, 2006 Share Posted February 6, 2006 jan15, I think Chris means something a little more advanced. In my passing familiarity of Powercadd you were able to define the nudge distance as a real value, 1/4" or 12" etc. It meant that you could be at any level of zoom and be moving the object the same amount. HTH Quote Link to comment
alanmac Posted February 7, 2006 Share Posted February 7, 2006 I like it just how it is, zooming in or out to control the level of nudge suits me, so I know that the closer I get the finer the movement. Alan Quote Link to comment
jan15 Posted February 7, 2006 Share Posted February 7, 2006 quote: Originally posted by ionw: ...In ... Powercadd you were able to define the nudge distance as a real value, 1/4" or 12" etc. ... you could be at any level of zoom and be moving the object the same amount. But what you've described is VW's "Move Objects on Grid" function (new since v9 or 10). You set the 1/4" or 12" as the "Snap Grid" distance (Page > Set Grid), and then each arrow stroke moves the selected objects 1/4" or 12", regardless of zoom. Only one click and one numeric entry to change the setting, and the function is always active, using your choice of shifted or unshifted arrow keys. Powercadd has something better than that? Quote Link to comment
ionw Posted February 7, 2006 Share Posted February 7, 2006 Only easier in this way, there is a status window that pops up, where you could: enter the amount directly, select from presets, (also a list of recent used distances) or choose to move via pixel defined distances (like VW) The nicety was that you could easily have a quickly accessed list of distances you could use, you didn't have to go in and reset the grid each time you wanted to use a different distance. Look I'm not trying to start a CAD peeing contest. 98% of my 12 years using CAD has been MiniCAD/Vectorworks. I was simply pointing out another program's tool, one that every PowerCADD user I have trained on this program has asked for. Truth be told I do not use the snap to grid, nor do I use the Nudge command I simply know how they work, so I don't know how much authority I bring to this conversation. [ 02-07-2006, 02:54 PM: Message edited by: ionw ] Quote Link to comment
jan15 Posted February 7, 2006 Share Posted February 7, 2006 Actually, I don't use "Move Objects on Grid", either. I never even turn the snap grid on. I use "Nudge" quite a bit, but only for exact positioning of text or images. Quote Link to comment
