Hello - hoping someone can help someone very (very) new to Vectorworks.
I've created a basic model I want to export to Illustrator, and reading online/on here exporting as a .DWG is the best way to retain vectorised artwork. I plan to use Vectorworks to produce basic 3D models and then do my final annotation and tweaking in Illustrator.
Image 1 shows my model in Vectorworks. It all renders as a having white/default fill. The lower section was made by drawing a rectangle and extruding, and the top (roof) section was made in four parts from polylines.
Image 2 shows the model in AutoCAD. Whilst I have no intention of opening these drawings in AutoCAD, I wanted to check i was getting the same issue as when I open in .AI...
...which is image 3. Essentially the lower section is just a group of single lines, with no fill/nothing to fill. The upper section consists of polygons (one filled white no lineweight, one no fill with a lineweight, grouped together) but as you can see it's been mixed up.
The drawing is going to be reasonably complex in the end, so adjusting this all manually in Illustrator isn't an option. I need something I can select all and change the line weight/colour, and then something I'm about to dynamic fill into to choose colours.
When using Rhino previously to achieve this, I used 'Make2D', which although a little glitchy at times got me a reliable drawing that worked.
Any advice? Apologies if this has come up before, I tried searching as best possible.
WilliamTurner
Many thanks.
4 answers to this question
