Carolina Hdz
HELIODON COLORS PROBLEM
Hi! Good Morning.
I'm having a little problem with my Open GL views.
I put my heliodon info in my city, with my parameters but i don´t know why the image in my camera views turns this "greenish" color when i turn my shadows on.
I'm attaching both pictures, the one without shadows but with the heliodon, and the one with the heliodon shadows, PLUS the one without the heliodon on so you can see the difference, to see if someone can help?
I'm also showing you my heliodon info to see if maybe i'm doing something wrong that's causing this color problem.
Thanks!
Carolina Hdz.
Hmm. Interesting. Might have to do with light passing through or reflecting off some green object(s)? Just out of curiosity, if you have Renderworks try rendering in the Renderworks Style "Realistic Exterior Final" and see if the result is any different. (Note this RW Style may take a bit of time to complete the render).
If you want to post your file, I or someone can have a look...
Posted (edited)
@Carolina Hdz check the class and object attributes for your heliodon.
I just recreated your problem by changing the color of the heliodon to green in the attributes panel.
Hope that’s it, if so it’s an easy fix 🙂
Edited by jeff prince
