Revision Cloud line weight
It seems odd that when you change the lineweight of an existing revision cloud, the configuration of the billows change slightly.
Why would the lineweight affect the shape? Even stranger is that if you pick the same line weight over and over again, the cloud regenerates each time with a different shape.
It would seem to me that only one cloud shape should be generated by a particular polyline shape regardless of the lineweight, and should be solely based on your choices for billow height and billow radius.
