shodkin 1 Posted July 3, 2020 Hello, I was hoping someone would be able to help me invoke the "Simplify Polys" command on a selected poly using vectorscript? I have a function that draws a very detailed polyline, using a large number of vertices. This function is used to create polylines for a few different applications, some of which require a lot of vertices and others which don't. I currently have to run the script and then go through manually afterwards and use the "Drafting Aids > Simplify Polys" command but I was hoping to be able to write this step into the script, getting the level of detail from a dialog box, somehow? DoMenuTextByName doesn't seem to work when just passed 'Simplify Polys' and there does not appear to be "SimplifyPolys" in the VS Reference Many thanks in advance and sorry if the answer is already out there. Quote Share this post Link to post
LarryO 18 Posted August 12, 2020 Just guessing here, It might be one of the tools that require calling via the custom tool call function in the same manner that one would call a PIO. Quote Share this post Link to post
