ErichR Posted January 24, 2006 Share Posted January 24, 2006 I am no longer able to add a class without v12 crashing. [ 01-24-2006, 02:36 PM: Message edited by: ErichR ] Quote Link to comment
ionw Posted January 24, 2006 Share Posted January 24, 2006 How about in a completley fresh document? Any information on your setup? Quote Link to comment
ErichR Posted January 24, 2006 Author Share Posted January 24, 2006 Exported the document to V11.5.1, and added a class with no problem. On a fresh document, V12 adds a class with no problem. Microsoft Windows XP Professional System Model Dell DXP051 Processor x86 Family 15 Model 4 Stepping 4 GenuineIntel ~3192 Mhz Processor x86 Family 15 Model 4 Stepping 4 GenuineIntel ~3192 Mhz Total Physical Memory 4,096.00 MB Quote Link to comment
ionw Posted January 24, 2006 Share Posted January 24, 2006 if you open the v11 file you exported back into 11, do you have the same problem. We used to rescue v9 files by back exporting to v8 and then opening in 9. Alternatively, you can use the workgroup reference method to recover from corrupted files PDF document Download the above document, and see if that clears things up. HTH Quote Link to comment
ErichR Posted January 24, 2006 Author Share Posted January 24, 2006 Thanks for your suggestions, Ionw. Imported the exported v11 file, so it's now v11v12v11v12. And it still crashes upon adding a class. One option is to use v11 until 12.1 is issued (and hope for a fix). Another would be to try your workgroup reference trick. Another is to go back to yesterday's backup, which doesn't seem to be corrupted. I could simply copy the latest stuff into the backup file (since the bad file does, at least, open). Quote Link to comment
ionw Posted January 24, 2006 Share Posted January 24, 2006 If you decide to go the copy paste route, I would highly recomend doing it in a very methodical fashion, testing adding classes after each paste and multiple saves, so that you can paste info in, see if the class issue causes a crash and if not save, if so then revert to saved rather than Undo. This way you may find the culprit in the new file. Also, another thought, have you only tried to add one particular class? i.e. Furniture, multiple times or more varied like Furniture, test, Gosh_darnit, #$%#@ If it has been only one name, try a different name to see if your class is causing a conflict with a plugin you added since yesterday... just a thought ion Quote Link to comment
jchrist Posted January 25, 2006 Share Posted January 25, 2006 If it adds a class in a fresh document without crashing I suggest that it's a corrupt document that's the problem. To fix open a new document use the workgroup references to copy all the layers and classes that existing from the corrupt doc, then delete the WGR but keep the information when prompted. Quote Link to comment
