deadpool Posted July 3, 2020 Share Posted July 3, 2020 Why sometimes when I subtract solids, I gets a hollow shape, but sometimes I gets a solid fill? I am using the exact same procedure, thank you. Quote Link to comment
Pat Stanford Posted July 3, 2020 Share Posted July 3, 2020 You mean like the object at the top left? If you were saying this was happening when you extrude an object I would say that the polygon you are extruding was not closed so there is no face to extrude, only the line. But since you are Subtracting I don't know, but I would probably start by checking that all the original objects are closed. 1 Quote Link to comment
iswope Posted December 23, 2020 Share Posted December 23, 2020 (edited) Any chance there Has been a resolution to this issue? This is with a swept rectangle with a pitch. Might it have something to do with the fact that one needs to include a 2d locus point to make a helical sweep? or the compound curve it creates. Update: if I do a positive pitch and then mirror it, it appears to work. 🤔 Edited December 23, 2020 by iswope 1 Quote Link to comment
