Lisar 0 Posted June 30, 2020 I have my site model set to 3D display "proposed only" and 3D style "3D mesh". The mesh lines show up and disrupt/distort my hardscape and landscape areas when I set up viewport images. Is there a setting to turn off to these triangulation lines ? Or do I have something else set wrong? Thanks in advance. Quote Share this post Link to post
Boh 439 Posted June 30, 2020 Hi Lisar If it is OpenGL render turning off “show outlines” (or similarly named) in the render settings might do it. If not could always make a copy of your Dtm, ungroup it and it should convert to a mesh. You can then go into the mesh and set all line work to 0 lineweight. That should get rid of the lines. Btw you image looks quite pixelated, you might want to increase the DPI. Quote Share this post Link to post
