Speedy Gonzales Posted January 19, 2006 Share Posted January 19, 2006 Hi all. I hope someone can help me on this. I have various view ports for a site plan used over different sheets. I have all the classes for these viewports turned on from the main class setting area. When the viewport is visible, I also make sure that in the Object Info box I have the same classes visible. However, after flipping back and forth between sheets and making a few changes, I tend to "lose" the viewport with the site plans. I have to go back and turn on those same classes again to regain visibility. Am I missing a setting or doing something wrong, or could this be a bug? Thanks in advance! Quote Link to comment
CipesDesign Posted January 19, 2006 Share Posted January 19, 2006 Are you perhaps using "saved views" ? If so, maybe one (or all) of them need to be edited to make all classes visible??? Quote Link to comment
Speedy Gonzales Posted January 20, 2006 Author Share Posted January 20, 2006 No saved views, just viewports. It is a file that originated in version 11.5.1. I recall having this problem on this same file then, too. It just seems that the settings won't stick. Thanks for the attempt to help. Quote Link to comment
Vectorworks, Inc Employee Biplab Posted January 23, 2006 Vectorworks, Inc Employee Share Posted January 23, 2006 Please submit a bug with the relevant info using: http://www.nemetschek.net/support/bugsubmit.php Quote Link to comment
