Paolo
PIL module import fails on some Windows computers
Posted (edited)
I distribute a plugin written in Python that makes use of the PIL module.
To import the module I use the Marionette function VerifyOrGetLib() as seen in some marionette examples from Marissa Farrell and others.
	if platform == 2: #windows
		PIL = 'https://pypi.python.org/packages/bb/f7/d644a9a65a25ff0bf43b7f69ce3ef9803742a5d6e438ddfc7e925c007e6c/Pillow-7.1.2-cp35-cp35m-win_amd64.whl#md5=6d62274af5c88c1cfe31c977f7531ed6'
	else: #Mac
		PIL = 'https://files.pythonhosted.org/packages/7d/b4/755848342213bcb5a5c570657ca21f20ebc104daf15d7847b08e18b4d2fd/Pillow-7.1.2-cp35-cp35m-macosx_10_10_intel.whl'
	if Marionette.VerifyOrGetLib('PIL', PIL):
Now I am receiving messages from some Windows users saying the installation fails.
Unfortunately I am on a Mac and cannot test it directly.
While the directory Python Externals is correctly created inside the user folder a message is shown saying that the module cannot be downloaded.
But the above link, if copied directly in a browser, indeed download a 2Mb file (Pillow-7.1.2-cp35-cp35m-win_amd64.whl)
Here's the code of the VerifyOrGetLib() (contained in the Marionette module)
def VerifyOrGetLib(missingLib, missingLibURL):
	# try to install user's package
	exit_code = False
	appfolder = vs.GetFolderPath(1)
	appuserfldr = vs.GetFolderPath(12)
	cmd = 'Python Externals'
	cmd = appuserfldr + cmd
	if not os.path.exists(cmd):
		os.makedirs(cmd)
	try:
		try:
			importlib.import_module(missingLib)
			exit_code = True
		except ImportError:
			#show dialog here
			question = 'Python module ' + missingLib + ' is not installed. Would you like to download and install it now?'
			res = vs. AlertQuestion(question,'', 1,'','','','')
			if res == 1 :
				if sys.platform == 'win32':
					piploc = 'Python35\Scripts\pip3.exe'
					pathpip = 'Python35\Scripts'
					cdpath = os.path.join(appfolder, pathpip)
					cmdpip = os.path.join(appfolder, piploc)
					wd = os.getcwd()
					if os.path.exists(cmd) and os.path.exists(cmdpip):
						os.chdir(cdpath)
						ret_code = subprocess.call([cmdpip, 'install', missingLibURL, '-t', cmd ])
						if ret_code > 0:
							vs.AlrtDialog('Module ', missingLib, ' cannot be downloaded.')
							exit_code = False
						else:
							exit_code = True
							sys.path.append(cmd + '\\')
							os.chdir(wd)
							vs.AlrtDialog('Module ', missingLib, ' has been successfully installed.')
				elif  sys.platform == 'darwin':
					import pip
					import shlex
					pos1 = missingLibURL.rfind('/')
					pos2 = missingLibURL.rfind('whl')
					downloadedfile = missingLibURL[pos1+1:pos2] +'whl'
					destination = appuserfldr + downloadedfile
					command_line = "curl -o " + '\"' + destination + '\"' + "  "+ missingLibURL
					args = shlex.split(command_line)
					ret_code = subprocess.call(args)
					if ret_code == 0:
						sys_executable_orig = sys.executable
						sys.executable = '/usr/bin/python'
						ret_code = pip.main(['install', destination,'-q','--target', cmd])
						sys.executable = sys_executable_orig
						if ret_code > 0:
							vs.AlrtDialog('Module ', missingLib, ' cannot be installed.')
							exit_code = False
						else:
							exit_code = True
					else:
						exit_code = False
					sys.path.append(cmd+'/')
			else:
				exit_code = False
	except:
		pass
	return exit_code
Is someone experiencing the same problem?
Any help is wellcome!
Edited by Paolo
Is there someone that can test the marionette node contained in this file (it should install PIL python module in the user folder) on Vectorworks 2020 SP4 on Windows?
Download PIL.vwx
It worked some time ago, it does not anymore.
Something has changed with the recent SP4 (maybe) and the VerifyOrGetLib() seems to refuse to install python modules.
I have checked (on Mac) and VerifyOrGetLib() is identical to SP3 version (see the code in the first post).
The bug should reside in pip3.exe, since the ret_code is 1 (what does it mean?), see code below.
I have no way to test it by myself, cause I am on Mac (and Mac does not have this problem…)
any help?
@Marissa Farrell, @JBenghiat, @relume
					wd = os.getcwd()
						os.chdir(cdpath)
						if ret_code > 0:
							exit_code = False
						else:
							exit_code = True
							os.chdir(wd)
Posted (edited)
I really wished I seen this thread yesterday...
Something has definitely broken within VerifyOrGetLib / Pip.
I was just about to release a new plug in package, and was doing some final testing, and discovered that my external libraries installation script has stopped working for some reason. I've posted my install code below, (very similiar to ops). I should note i'm doing this on windows, haven't tested on Mac.
import shutil
import os
import vs
import Marionette
import platform
import sys
def installOpenSSL():
    Usr = vs.GetFolderPath(-12)
    (major, minor, maintenance, platform, buildNum) = vs.GetVersionEx()
    if platform == 1:
        Path = Usr + 'temp/tempImg.png'
    else:
        Path = Usr + 'temp\\tempImg.png'
    vs.AlrtDialog(str(sys.version))
    module = 'https://files.pythonhosted.org/packages/9e/de/f8342b68fa9e981d348039954657bdf681b2ab93de27443be51865ffa310/pyOpenSSL-19.1.0-py2.py3-none-any.whl'
    if Marionette.VerifyOrGetLib('OpenSSL', module):
        pass
    else:
        vs.AlrtDialog('Error Installing Module')
installOpenSSL()
I tried skipping the Marionette call, in case the issue lay somewhere within there and invoked the subprocess.call directly, which returns Error code 1. To gain some slightly better feedback as to what was going on I swapped to subprocess.Popen. I tried a combination of different pip commands, the below code should list all installed packages.
import vs
from collections import OrderedDict
import operator
import copy
import  os, sys, subprocess, urllib.request, importlib, logging
import itertools
ret_code = subprocess.Popen([cmdpip, 'pip list'  ], stdout = subprocess.PIPE, stderr=subprocess.STDOUT )
output, err = ret_code.communicate()
vs.AlrtDialog(str(output))
vs.AlrtDialog(str(err))
For all commands the error I get is:
  File "D:\Program Files\Vectorworks 2020\Python35\Scripts\pip3.exe", line 1
SyntaxError: Non-UTF-8 code starting with '\x90' in file D:\Program Files\Vectorworks 2020\Python35\Scripts\pip3.exe on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Now i'll be honest just getting this far has stretched my coding knowledge, and I don't have the knowledge to suggest any fixes or solutions from this point.
I also accept there's a high chance my use of subprocess commands may be the reason i'm getting this particular error, however there's no denying somethings broke since SP4
Edited by tbexon
Double check that the "'pip list'  " you have written as a parameter to subprocess.Popen has no special character.
Hi @tbexon,
thank you for your thorough investigation, I too ended beyond my knowledge, also I am on Mac and not able to test any solution directly.
So I have ended up suggesting manual installation of modules to my (Windows) plugin users.
Also the Marionette.VerifyOrGetLib bug has been reported, so I hope it will be fixed soon.
If my understanding of what I read here is correct
It should run without any special characters, however I tried "pip install" as well which definitely doesn't require any special characters to run.
As a work around can anyone think of any reason why adding into the install.py script some code to manually copy what would normally be the final contents of external python packages into the user folder?
@Paolo ,
Could you please report the exact number of the build 2020 sp4 you are using?
Could I have also any available information about windows (version, build), where the problem with pip 3 occurs.
Do you have any other python installation on your PC ?
I have tested your file Download PIL.vwx with 2020 SP4(551884), everything seems OK.
I have Windows 10 Pro, build 1903.
Please, take a look at the attached video.
18 hours ago, tbexon said:
cmdpip, 'pip list'
Thank you @K.Lalkovski,
as stated in my previous posts, I report problems from Windows users with 2020 SP4.
From my side (2020 SP4 on MacOS) all is working.
I will ask them to send me more details on this and post them as soon as i get them.
@Paolo If possible let the user  execute the following script from the command line. Goes to Python folder of VW(Python35).
import sys
import locale
print("sys.stdin.encoding = ", sys.stdin.encoding)
print("locale.getpreferredencoding = ",locale.getpreferredencoding())
print("locale.getpreferredencoding = ",locale.getpreferredencoding(False))
print("sys.getdefaultencoding = ",sys.getdefaultencoding())
print("sys.getfilesystemencoding = ",sys.getfilesystemencoding())
@K.Lalkovski
I'm on SP4 Build 550627 - Which I notice is a different build to yourself, I THINK i'm on the most up to date version, as I tried reinstalling VW from a fresh download as part of my fault finding process.
output from script:
=== RESTART: D:\Program Files\Vectorworks 2020\Python35\get encoding info.py ===
sys.stdin.encoding =  utf-8
locale.getpreferredencoding =  cp1252
sys.getdefaultencoding =  utf-8
sys.getfilesystemencoding =  utf-8
@tbexon Thank you for the info. Could you please execute this script as well?
import sys
print("sys.getwindowsversion = ",sys.getwindowsversion())
@tbexon Could please try this pip3.exe in the attached archive pip3.zip
1.Goto VW folder\Python35\Scripts
2.rename old pip3.exe to pip3old.exe
3.unzip new pip3.exe.
4.Start VW and try on your machine the script above that was giving the error "SyntaxError: Non-UTF-8 code starting with '\x90'" in file D:\Program Files\Vectorwork". Report the results here.If there is no more such a syntax error try to download PIL for Python 3.5 via Marioentte.VerifyOrgetLib and let me kknow about the result.
pip3.zip
