symo
Problem with rendering with VW light symbols
Posted (edited)
Ive posted this in the Rendering forum also.
Ive started seeing a strange issue whereby I create viewports on sheet layers, override the light objects (both from Spotlight & RW lights) until it looks right, render, close the file, re-open, re-render - then all of my Spotlight light objects turn-off for no apparent reason. The VW light object dont do this. I then need to go back to the design layer and re-create the viewport to get it to render properly.
Ive attached a sample file with most of the geometry ripped-out (for IP reasons).
Render test.vwx
Another problem that I regularly run into are VW light objects blanking-out their names when I try to edit them in the Visualisation/Lights palette - normally when I select multiple lights and edit several at once. When this happens, I cant edit them in the sheet layer.
Any insight would be appreciated.
Edited by symo
@symo Be sure you are using 2020sp4. We have seen some files exhibit the rendering problem but believe we have resolved in sp4.
Hi Kevin
Cheers for the update. Looking forward to SP4!
