markdd
Plug-in or Parametric Object
I've noticed over the years Vectorworks uses the terms Parametric and Plug-in  interchangeably. Is anybody able to help me make the distinction? This is further confused by the use of Plug-in Style
My leaning is towards calling every tool that creates geometry based on parameters set by the user as Parametric. However, I keep seeing tools that do just that being referred to as Plug-ins!
Any help with clarification would be really helpful.
Many thanks
A Parametric object is a VW object of type 86 (constant kParametricNode in C++).
As for "plug-in", I would say anything that is in the folder Plug-Ins, to add functionality in VW.
A tool, especially a third-party one, is probably going to have parametric object associated to it, but it does not need too. (E.g. you could have a tool creating a polygon.)
A parametric object alone cannot be placed in a VW document, you need a tool, a menu (or a call by a script or other code).
Edited by Nicolas Goutte
I would see even many 2D Objects like Lines and Rectangles as parametric.
As you can all time edit them in OIP numerically.
Or Extrudes, Solid Additions/Subtractions, ...  by OIP and Edit Mode.
AFAIK
PIOs (PlugIn Objects) are more complex Objects like VW's Doors, Windows, Walls, ...
Internally in VW, all those are not Parametric objects, as they have other object types.
So the parametric comes from the Tool, not the Object.
Or do I use the term parametric wrong ?
For me as a user a VW Rectangle is parametric because I can
change its parameters like Length and Width.
No, it is the object which is Parametric. The tool is just a tool to be able to place it into the document. (Sorry, for the recursive definition. 😃)
Quote
My definition comes from the internal object types.
Quote
Sure that would be another point of view. That is probably why it is not easy for somebody not knowing object types to see a difference.
However seen that way, every object of VW has a OIP where something can be changed (be it its position). (That is probably the definition of a PIO.)
Thanks for your responses.
Can I summarise so far by saying that:
  1. Tools in the Basic Tool Palette such as Line, Rectangle, Circle, Polyline, Polygon etc..... are tools that create Parametric objects.
  2. Tools like the Door, Window, and Wall tool are Plug-in tools that use the parametric tools (above) to create their respective Door, Window and Wall Plug-in objects.
If that is the case, then what is the role of a PIO (which I have to confess I always thought was short for Plug-in Object)?
Mark
Edited by markdd
For me, they are not parametric, as they have other object types. (And they are no Plug-Ins either, as there are defined in VW itself, as far as I know.
Quote
  1. Tools like the Door, Window, and Wall tool are Plug-in tools that use the parametric tools (above) to create their respective Door, Window and Wall Plug-in objects.
Wall is very internal in VW too, so it is not a Plug-In. Also it has a separate object type too.
However Door and Window are parametric objects and Plug-Ins.
Quote
I would say anything that is an object which is defined as Plug-Ins. Thinking about it, I think you cannot defined any other type of object that a parametric in a plug-in (alternatively you can define a menu, a tool or library code). So at the end a PIO is probably the same as a Parametric object (unlike what I have written in the meantime).
Thanks Nicolas
I am no nearer a resolution to this! I think I am probably trying to be too reductive and that the issue is more complex than I thought.
Mark
You could define it in another way (a bit simplified perhaps):
- a plug-in is something listed in the Plug-In Manager
- an object listed there is parametric.
OK.
There are essentially two types of object in the plug-in manager. Tools (and menu commands) and Objects.
The Tool that makes the object is a Plug-in. The Object that is made by the tool is a Parametric Object.......
Am I getting closer?!
9 minutes ago, markdd said:
OK.
Yes, I think you are getting closer.
However an object would be a Plug-in too. You can see Plug-ins as something that tells VW: "Here are some extensions: this tool ATool, this object A, this menu B, this code library C". Normally a file containing code file, especially from C++, defines more that one "thing" (that is my naming).
Ok!
Can you give me a few examples of an object that is a Plug-in object and an object that is just parametric? That might help my understanding a bit better....
Thanks for this btw!
4 minutes ago, markdd said:
Ok!
As written above, I do not think you can define an object in a Plug-In that is not a Parametric object.
Otherwise a Parametric object that would not be a Plug-In would be needed to be defined in VW itself. I am not sure if there is any. (If it is defined in VW, it could have its own object type.)
Thanks too. This thread makes a few things clear for me too, that were not so clear before.
Pat. This is terrific. Thank you .
Your concise essay should now definitely be part of the help files.
If “Parametric” refers to any object that can be changed in the Object Information Palette, then a Group and a non-scalable Symbol are about the only objects that I can think of (off the top of my head) that are non-parametric and non-Plug-in?
It is really the difference between the dictionary definition (a Parametric Object is anything that can be changed by a parameter) versus the colloquial definition (a Parametric Object is an object that more than just the size can be changed by a parameter).
Let's not go to Groups and Symbols because then I have to go into the entire Container Object discussion, which will devolve into the nested class visibilities discussion, which will devolve into Document Visibilities versus Viewport Visibilities which will devolve into ...) ;-)
But you are correct that are not many things in VW that are not dictionary definition Parametric.
I’ve been contributing to this forum long enough to know what rabbit hole that could turn into!!
Thanks again Pat.
