nahekul Posted June 24, 2020 Share Posted June 24, 2020 Hi, Is there a way to create a filter definition that contains multiple layer names? For example, if I want to filter out layers that are plans, sections, and elevation, I can add multiple criterias similar to how custom selection is done. Currently, the layer filter only allows one entry of each definition, so I can only create a filter that separate out plans, or sections, but not both at the same time. The current work around is to add 1 tag (eg. PSE) to all three types of layers and filter that tag separately. But this is not ideal since sometimes you want just plans and elevations or plans and sections. Then you need tags for those combinations as well. Quote Link to comment
