Ok, I'm new here, so this may be an easy/obvious fix but...
When I import a drawn plan at a particular scale, how do I communicate to Vectorworks what the reference is for the scale?
I know I set the new document to the same scale as the drawing, but how do I sync the new document with the pdf? In other programs I've been able to scale the drawing by going into a mode where I measure a known dimension on the drawing so the program has a size reference for the drawing.
I followed the directions in someone else's question which said to go into Modify> Scale Objects... I drew a line on a known dimension and entered the resulting number into Current Distance in Symmetric by Distance, then I entered the correct measurement from the drawing. I hit OK, scaled the whole thing, but the measurements are still off by several feet in my document.
DWrightLocal80
Thanks in advance
10 answers to this question
