taoist Posted June 19, 2020 Share Posted June 19, 2020 (edited) Something I discovered while working on stacked wall components. Stone on lower section of wall, vinyl siding upper section of wall. In this case 9' wall 42"of stone, vinyl siding above. I put the stone as 1st item in "stack", offset the top down -66" Vinyl siding second item in "stack", offset bottom 42" up. Siding is 1" Thick Stone is 2" Thick This way works as I intended. When I put Vinyl Siding on top, did not get same results. Way Cool! Rod Edited June 19, 2020 by taoist Added information Quote Link to comment
