Stacked Wall Components
Something I discovered while working on stacked wall components.
Stone on lower section of wall, vinyl siding upper section of wall.
In this case 9' wall
42"of stone, vinyl siding above.
I put the stone as 1st item in "stack", offset the top down -66"
Vinyl siding second item in "stack", offset bottom 42" up.
Siding is 1" Thick
Stone is 2" Thick
This way works as I intended.
When I put Vinyl Siding on top, did not get same results.
Way Cool!
Rod
Edited by taoist
Added information
