Is there a way on Vectorworks to make material id or render channels?
Ami
Hi,
I'm still very new to Vectorworks and want to know if is there is away to make a render channel (e.g. alpha channel) or material ID?   I enjoy manipulating my rendered photos after on photoshop as it just makes it easy using the wand tool to select a certain area of the photo. If there's a way of doing it can you please explain how?
Thanks
Edited by Ami
Interesting question, I would like to know how to accomplish this too.
You can export your render with an alpha channel.
thats handy for dropping your rendered objects onto a different background.
I’m not sure if it is possible to export each object with an alpha... I doubt it.
If it’s not possible, i suppose you could turn off classes or layers, render, and export each one individually.
Seems like a great job for a script if the scene was complicated, but it could present too much work in an image editor to reassemble.  It would be cool to have a render method that facilitated changing DOF after the fact. I had an actual camera that could do that.
