Davy Posted January 13, 2006 Share Posted January 13, 2006 After I installed the latest security updates from Micros..t VW 12 will not finish starting up due to an error with quicktime. I've tried every version of quicktime from the ones on the VW install disk up through the latest version. Same problem. Any suggestions. Thanks, Davy [ 01-13-2006, 03:24 PM: Message edited by: Davy ] Quote Link to comment
Guest Posted January 13, 2006 Share Posted January 13, 2006 Uninstall the current version of QuickTime that you have using Add Remove Programs and install the version that is on the VW 12 install CD. If that doesn't work - download the latest from apple.com/quicktime When installing, be sure to select a custom installation and select all components to be installed. Quote Link to comment
Davy Posted January 13, 2006 Author Share Posted January 13, 2006 Katie, I followed your suggestion. There is no choice of a custom installation. VW12 still does not work. Davy Quote Link to comment
Kevin Posted January 14, 2006 Share Posted January 14, 2006 Is this Windows or Mac? Quote Link to comment
mclaugh Posted January 14, 2006 Share Posted January 14, 2006 quote: Originally posted by Kevin: Is this Windows or Mac? Um ... Davy wrote: quote: After I installed the latest security updates from Micros..t Last I checked, Micros__t wasn't issuing security updates for Macs. Quote Link to comment
Davy Posted January 14, 2006 Author Share Posted January 14, 2006 Yes, it is a windows system. Davy Quote Link to comment
Guest Posted January 16, 2006 Share Posted January 16, 2006 Are you installing QuickTime from the install disc or downloading it from apple.com/quicktime? Quote Link to comment
Davy Posted January 17, 2006 Author Share Posted January 17, 2006 I've tried both methods including deleting the previous files from the control panel. Neither seems to work. Davy Quote Link to comment
Davy Posted January 24, 2006 Author Share Posted January 24, 2006 So no solutions yet? Davy Quote Link to comment
Davy Posted January 24, 2006 Author Share Posted January 24, 2006 I tried the solution here since I was also having problems with Firefox. It fixed that problem but not this one. http://discussions.apple.com/thread.jspa?threadID=323551&tstart=90 Quote Link to comment
Guest Posted January 25, 2006 Share Posted January 25, 2006 Davvy - Are the quicktime installations working, or are those too failing? The result of installing from the download or CD is unclear. Quote Link to comment
Davy Posted January 30, 2006 Author Share Posted January 30, 2006 Quicktime seems to be working in every other application. It works in both Internet Explorer and in Firefox and in iTunes. But still not in VW12. Davy Quote Link to comment
Ethan R. Posted February 1, 2006 Share Posted February 1, 2006 I believe I am having the same problem. I get the VW splash screen, but then it dissapears and I have nothing. is this what you are experiencing? thank you, Ethan Quote Link to comment
Davy Posted February 2, 2006 Author Share Posted February 2, 2006 I get the splash screen and then "Vectorworks Application has encountered a problem and needs to close. We are sorry for the inconvienence." When I click on the click here link to see what the error report contains I get: Error signature AppName: vectorworks.exe AppVer: 12.0.0.49891 ModName: quicktime.qts ModVer: 7.0.4.80 Offset: 000feef1 I got the same with quicktime 7.0.2 and 7.0.3 Davy Quote Link to comment
Ethan R. Posted February 3, 2006 Share Posted February 3, 2006 No I'm getting nothing from VectorWorks & nothing from Nemetschek!!! I've called, emailed, webformed and left messages!!! Nothing!! Quote Link to comment
Davy Posted February 6, 2006 Author Share Posted February 6, 2006 All I've gotten is the couple of replies to this post from Katie. But, no solution yet. Quote Link to comment
SteveK Posted February 7, 2006 Share Posted February 7, 2006 I have a user with the same problem, generating the same error message. First I uninstalled QT and reinstalled off the CD. That didn't work. I then reinstalled VW 12, which also didn't work. This computer still has VW 11.5.1 on it, so I tried opening that. VW 11.5.1 opened with no problems. So my quess would be something related to VW 12 is crashing and not QT. As far as I can tell, this computer has not has any software updates in the last week or so. Steve [ 02-07-2006, 04:13 PM: Message edited by: stevek ] Quote Link to comment
Guest Posted February 8, 2006 Share Posted February 8, 2006 I am currently investigating this problem with the engineering staff and will be in touch as soon as I have more information. Ethan - your problem is different. It sounds as though not all the components are being installed. When you installed from the CD, did you get a message alerting you that the installation was complete? Quote Link to comment
SteveK Posted February 8, 2006 Share Posted February 8, 2006 Thanks Katie. Let me know if I need to send a Dr. Watson log. Steve Quote Link to comment
Davy Posted February 14, 2006 Author Share Posted February 14, 2006 Stevek, It is also true on my computer that 11.5.1 still works perfectly. Davy Quote Link to comment
Guest Posted February 15, 2006 Share Posted February 15, 2006 For those of you having this problem, are you using a dongle? Quote Link to comment
Davy Posted February 16, 2006 Author Share Posted February 16, 2006 And I just updated to 12.0.1 and still have the problem. Davy Quote Link to comment
JustWannaDesign Posted February 19, 2006 Share Posted February 19, 2006 Im having the same problems. Using VW12, had Quicktime 7.04 already on my system. When I try to create a section viewport of a floor plan, I get the dreaded "Vectorworks encountered an error and needs to close"!! AAAhhh Eiieeie. Then it drops me out of VW. The error report identifies the problem as quicktime.qts file. I tried to uninstall, reinstall Quicktime, uninstall quicktime and delete Vectorworks (I have to do it manually since Vectorworks doesn't show up in my windows "add/Remove programs" window.(why not?). I even tried it with the just released VW 12.0.1 update. Still doesn't work. Any suggestions for a clear concise course of action, other than a try this, try that trial and error approach? Cheers Tim Quote Link to comment
JustWannaDesign Posted February 19, 2006 Share Posted February 19, 2006 Oh, also, I'm not using a dongle, and the program initially allowed me to create the section viewport on this same computer, but I was running it on Win xp 64 bit version, and didn't seem to have the problem, but switched back to running win xp 32 bit version because of other problems like unavailable drivers, software incompatibilities, etc. BTW, VW12 seemed to work fine with win xp 64 bit. My system: AMD 64bit dual core 4800 2 gig ram Geforce 7800 Gtx video 1 TB system (yeehaw!!) Quote Link to comment
