  • 2
Boh
Title Block Border Revision History Reports
Currently with the Titleblock Border Project Revision History Reports you can indicate the recipients of a drawing Issue, however unless a sheet has a revision number there is no indication that an unrevised sheet is included in an issue. The workaround is to add a revision to a sheet even if there are no changes simply so the sheet will get a revision number and thereby show that it is included in an issue on the Revision History report. Addin a revision number to a sheet simply for this reason I think should be unnecessary.
VW should consider adding a tick or some sort of marker to indicate unrevised issued sheets in the Revision History worksheet.
Another wishlist Item is for the default reports to be able to be be customised AND for the custom reports to shared throughout an office via a Workgroup Library. Curently custom reports are only available from User Libraries, not workgroup libraries. It makes sense, the first thing you want to customise on the report is to add your own company name and details, surely you want everyone in your office to easily access these custom reports?
Lastly, when doing reports for larger projects which might have 2 or more .vwx files associated with them, it would be very useful to be able to sort the sheet order so that they order by sheet number. At the moment the sheets are grouped per file so for example floor plans in one file won't list next to the floor plans of another file.
Thanks
Edited by Boh
  • Like 3
0 answers to this question
