sthodkin
Get and Set commands for objects
Hello,
I was wondering if there was any documentation on all the functions associated with objects in VectorScript?
As an example, I am trying to calculate the angular dimensions between all points on a closed polyline... The following script seems to do a nice job of displaying and Angular Dim Object at each point
Quote
FOR vertexNum := 1 TO GetVertNum(obj) DO BEGIN
    if (vertexNum = 1) then {Processes first vertex in polyline}
        begin
        {Get the current point}
        GetPolylineVertex(obj, vertexNum, ptX, ptY, vertexType, arcRadius);
        {get the pervious point}
        GetPolylineVertex(obj, GetVertNum(obj), prevPtX, prevPtY, vertexType, arcRadius);
        {Get the next point}
        GetPolylineVertex(obj, vertexNum+1, NxtPtX, NxtPtY, vertexType, arcRadius);
        end
    else if (vertexNum = GetVertNum(obj)) then {Process last item in polyline}
        begin
        GetPolylineVertex(obj, vertexNum-1, prevPtX, prevPtY, vertexType, arcRadius);
        GetPolylineVertex(obj, 1, NxtPtX, NxtPtY, vertexType, arcRadius);
        end
    else {Processes all other items in polyline}
        begin
        end;
    {adds angular dims to each corner}
    AngularDim(prevPtX, prevPtY, nxtPtX, nxtPtY, ptX,ptY,1.7001838",771,770,#35d 32'16");
END;
However I was wondering how I could get the dimension that is displayed "out" of this object? I know it can be calculated using tan θ =(m2−m1)/1+(m1m2) but I was wondering if there was a way of getting if from the angular dim that has been create?
Along these lines I was wondering if there is a reference somewhere that has all the various functions associated with objects in VectorScript? as examples: get(), set(), charAt() toInt etc?
Many thanks
The below will get you the string representation of the dimension value. If you need to convert it to a number you can use STR2Num()
GetDimText
VectorScript Declaration:
FUNCTION   GetDimText
( h:HANDLE ) :STRING ;
Python:
def  vs.GetDimText(h):
   return STRING
Description:
Function GetDimText returns the dimension value displayed with the referenced object.
Parameters:
hHandle to object.
Example:
DimValue:=GetDimText(HandleToObj);
