Matt Overton Posted June 12, 2020 Share Posted June 12, 2020 In short standard tools like the offset tool in modify (not duplicate) mode should not trigger this error. Better still slab modifiers should be improved to allow object creation even application reassignment in edit mode. 3 Quote Link to comment
0 E|FA Posted June 12, 2020 Share Posted June 12, 2020 Agreed. My workaround has been to enter the slab editor, cut the existing modifier, exit the slab, paste-in-place and edit the modifier, then use the edited modifier to re-modify the unmodified slab. A fix from VW would be appreciated. Quote Link to comment
0 Matt Overton Posted June 13, 2020 Author Share Posted June 13, 2020 13 hours ago, E|FA said: Agreed. My workaround has been to enter the slab editor, cut the existing modifier, exit the slab, paste-in-place and edit the modifier, then use the edited modifier to re-modify the unmodified slab. A fix from VW would be appreciated. I did just that about 8 times in about 10minutes not sure I'd call undoing back to scratch and redoing a work around. Quote Link to comment
Matt Overton
2 answers to this question
