  • 3
Slab modifiers should be editable with common edit tools.
Matt Overton
2 answers to this question
Agreed.  My workaround has been to enter the slab editor, cut the existing modifier, exit the slab, paste-in-place and edit the modifier, then use the edited modifier to re-modify the unmodified slab.  A fix from VW would be appreciated.
I did just that about 8 times in about 10minutes  not sure I'd call undoing back to scratch and redoing a work around.
