  • 3
Matt Overton
Slab modifiers should be editable with common edit tools.
In short standard tools like the offset tool in modify (not duplicate) mode should not trigger this error.
Better still slab modifiers should be improved to allow object creation even application reassignment in edit mode.
  • Like 3
2 answers to this question
Agreed.  My workaround has been to enter the slab editor, cut the existing modifier, exit the slab, paste-in-place and edit the modifier, then use the edited modifier to re-modify the unmodified slab.  A fix from VW would be appreciated.
I did just that about 8 times in about 10minutes  not sure I'd call undoing back to scratch and redoing a work around.
