MartinFahrer
Objects in resource manager behavior
I have a moldings resource manager.  Some I double click then on the third click I can place the resource in the drawing.  Others I double click and Vworks places it seemingly randomly on the design layer.  My question is there any way to edit the properties of placing a resource object on the design layer?
2 answers to this question
I've looked at all the variables I though may be a factor in this behaviour but none are described as nor produce the behaviour you're describing. I suspect a corruption of either:
  1. One or more objects that have this behaviour, or
  2. The file itself, or
  3. A Vectorworks system file.
Account for these possibilities by:
  1. Post your file (or a test one with suspect objects within)  here for someone else to test.
  2. Test for this phenomenon in ideal circumstances:
    1. Restart your computer -> re-check.
    2. Acid test: Go: File > New… > Create blank document (with only new symbols) -> re-check.
    3. Acid test: Go: File > New… > Create blank document (introducing your suspect symbols) -> re-check.
For some reason the original resource was created as nurbs instead of lines.  I had to edit in the 3D objects.  I basically Copied the nurbs, pasted into a document, converted to lines then composed. Finally saving the symbol.  Just in case some one has the same problem.
