Aaron59 Posted June 10, 2020 Share Posted June 10, 2020 In the title block border settings - Sheet Data, there are 2 different scale fields. One said "SCALE" with and 'update' button, and the other said 'Sheet Scale' What's the difference and which to use? Thankyou Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted June 10, 2020 Vectorworks, Inc Employee Share Posted June 10, 2020 Hello @Aaron59, The Scale field with the Update button is predefined field that will always be in the Sheet Data and cannot be deleted, only hidden. If you press the Update button it will get the scale of the layer, in which the TBB is placed in. If the layer is Sheet Layer, it will take the scale of the viewport in that sheet layer, if there is a viewport in it. The Sheet Scale field probably came from old title block and could be deleted or modified. If you do not want to have 2 scale fields, you can delete the Sheet Scale that does not have the update button. For more information about the Title Block fields, check the help site here - https://app-help.vectorworks.net/2020/eng/index.htm#t=VW2020_Guide%2FSetup%2FTitle_block_border_settings.htm&rhsearch=title block&rhhlterm=title block&rhsyns= Best Regards, Nikolay Zhelyazkov Quote Link to comment
