I've been testing my workflows on the schematic views. I ran into some issues, I am working on 2020 SP3. I did not convert to hanging position. The file is a new 2020 blank metric file.
I have 4 sticks of truss each truss has 1 fixture attached to it. If I make a schematic view from those, the placement, rotation and order of the fixture gets messed. This happens both in top and front view the first image below is the actual truss and fixture geometry, the second and third is the schematic view made from it.
If I put all 4 lighting devices on one piece of truss then the order and placement is correct, but the rotation is wrong. The first image below is the actual truss and fixture geometry, the second is the schematic view made from it:
A lot of movements of devices in the schematic views leed to out of date schematic view geometry. And also it is not possible to move a device in the schematic view from one truss to another. Again the first image below is the actual truss and fixture geometry, the second is the schematic view made from it:
Is there a workaround to avoid these issues? I did try to use a hanging position but that led to a very long conversion time and this schematic view also had issues. I did not continue testing those as I understood the truss system workflow is the way the program is headed now.
Sebastiaan
Hi All,
The VWX is attached.Schematic test.vwx
spelling
2 answers to this question
