Roof Joints
Try this:  edit the roof planes (select and < cmd+[ >), and drag the peaks of the each polygon beyond the junction.  Then join, making sure you are using the second mode as shown in the screen grab above (Dual Object Connect Mode).
If that does not work, just create a new roof from a rectangle, you should be fine.
