mbaron
Some plant record quantity numbers not showing in worksheet
I've made a planting plan, using place plant and created a report to list the plants (latin name, common name, sch size and quantity). Most of the plants all come out fine, but I have missing quantities in about 25% of the plants on the list and i can't figure out why. Quantity number just lists as --
Why would these plant numbers not be showing in the report?
1 answer to this question
The dash indicates that you have SUMmarized subrows and that the data in that column is not identical in all of the SUMmarized items.
Look in the database header row (ie 3, not 3.1, 3.2, etc.) [If you don't see the integer row, then go tot eat worksheet View menu and choose the Database Headers option] for that column, click on the down pointing disclosure triangle and make sure the Sum Values check box it checked.
