MartinFahrer
Wireframe to Open GL
10 answers to this question
When you change to a 3D view, what is then checked under View > Rendering?
Does the object have a solid fill in the Attributes Palette?
Wireframe is even though I have it set to Open GL
Yes solid fill see below this is when I manually change to open GL
Hmm, not sure then. I haven't heard of any bugs related to this, but who knows...
I assume you've tried a full restart?
Yes a couple times, I might be missing something will call support tomorrow.
Try a Rest of your Preferences. The button at the bottom left of the preferences screen. You will have to reset everything afterwards, but it sounds like this might fix your problem.
This happens to me occasionally, but I haven't put the time in to see if there's a pattern.  I think it's happening when I exit out of certain tools or editing modes.
We chased this last week also and found that the automatic switching does not happen when you are in Edit Group (or I would assume Symbol) mode, only when you  are directly on a design layer.
And I meant Reset your preferences, not rest them. Although after this week I think I would like to rest my preferences.
@Pat Stanford That sounds about right.  Has a bug report been submitted?
I did not submit a bug. If this is important to you I recommend that you do so.
Bug report has been submitted
