I am a student and trying to learn Vectorworks Landmark by using your tutorials.
I would like to create a sheet and import an info bar with text and scale etc for my landscape design. Does the student version not have any ready made templates? It seems like I can import a sheet layer somehow, but where from? There is nothing there.
Sheet layers exist already you just need to create a new one. as for your info bar, I believe you are talking about the Title Block. There are a few in Vectorworks already. just go to Dims/Notes and select the Title block tool. here you can select a TB of your choice from the dropdown selector in the mode bar.
OK. Where do I find the Dims/Notes ?
I only have the 'Basic' and the 'Tool set' on the left in my view.
Its the one you are showing highlighted in blue!
Sorry, yes it is just a screen shot from a tutorial and not mine😄.
This is the palette I am after but I am afraid I can't find in my set up.
Go to TOOLS> WORKSPACES>DESIGNER set the check in front of designer. then see if you have the options.
Also make sure that you have your basic toolset on.
Noop. I have also switched between all the different workspaces eg Architect, Landmark etc.
The basic toolset is on.
could you take a screenshot and post?
Pull your tool set out of its docked position. At the bottom of that window you will seen arrow. select this and set "view tool sets as" then select "Icons". This should show all the tool sets.
How can I change from imperial to metric in resource manager? My plants all show inches but I would like this to be in mm or cm.
I don’t think you can change these as the a record fields of the plant symbols in the Vectorworks library file.
