aqdavidson Posted May 29, 2020 Share Posted May 29, 2020 Hi, I am working with a designer that uses VectorWorks and we use AutoCad. Any suggestions on how to convert the .vwx to .dwg? Do I need to have the VW software? Any help is appreciated. Adam Davidson, P.E. AD Engineering Group Quote Link to comment
michaelk Posted May 29, 2020 Share Posted May 29, 2020 Vectorworks can import and export .dwg directly. If it fits your workflow VW can also import IFC, Revit, Cinema 4D, PDFs, Shapefiles, .3ds, .obj, .stl, Rhino, Parasolid, and Sketchup, plus a few more and export PDF, Shapefile, .3ds, 3D PDF, Cinema 4D, .obj, .stl, Rhino, Parasolid, plus a few more. When round tripping dwg to vwx it will be useful to experiment with the import/export dwg settings to make sure you are getting back the dwg formatting you like. 1 Quote Link to comment
ColinW Posted May 29, 2020 Share Posted May 29, 2020 Ask the designer to export their file from VW into a dwg version compatible with your AutoCad version. VW can export to most dwg versions. It’s useful if they supply a pdf version of the file so you have a visual reference in case there are are any obvious issues with the exported file. 1 Quote Link to comment
aqdavidson Posted May 29, 2020 Author Share Posted May 29, 2020 Thanks michaelk and ColinW for the help. Quote Link to comment
dtmiller Posted March 5 Share Posted March 5 I have this playground file from a Landscape Architect. can someone convert this to .dwg for me, please and thank you LC-4 PLAYAREA.vwx Quote Link to comment
Jonathan Pickup Posted March 5 Share Posted March 5 Is there a reason why the Landscape Architect won't export that as a DWG file for you? Quote Link to comment
