Andy Broomell
Texture transparency: semi-transparent pixels darken
Posted (edited)
Here's an issue I've had for years... I'm curious if anyone knows why it happens or if there's a fix.
The basis of the problem is that areas of a texture that are semitransparent seem to also get darker in value when rendered. For example, here I have an image prop that is a soft-edged yellow circle (imagine perhaps it's the halo around a light or something). It should look like this:
1591789623_ScreenShot2020-05-28at12_08_29PM.thumb.png.8e574727489dd01fa89a12904cf28649.png
But when rendered in Renderworks it looks like this:
2085523248_ScreenShot2020-05-28at12_06_01PM.thumb.png.5298120d05b35b6c34db7a63c30a7cb3.png
The pixels should only range from yellow to white, where is that darkness coming from?
Vectorworks file:
Transparency_Issue_v2020.vwx
Transparency_Issue_v2018.vwx
Edited by Andy Broomell
If I change the colour shader to just plain yellow and then I get this result. Do you think that there is some sort of "interference" with the image pixels from one image to another that is causing the shadow effect?
It does seem to be something like that. Strange...
I wonder if someone from Vectorworks can elaborate on what's happening with the combo of the two images' pixels.
I should mention that I'm not typically using a simple solid-color image like in the example, but in this case changing the Color shader to plain Color would be a workaround.
Is ambient occlusion coming into play here? I wouldnt think so, but it looks like it. *longshot
