cut and paste of symbols
StephenA
It probably doesn't. What it means is that the symbols you are pasting either are, or contain elements that are, in a class that is set to invisible. If you can figure out which class (or classes) the symbols are i n, then by making that class active your symbols will re-appear. It can be a little funny if you have pasted a bunch of them into the drawing - when they all reappear they may be sitting right on top of each other. Hope that helps.
