Data tag help
fabrica
7 answers to this question
Try this:
Set up your Data Tag to display the Custom Size Field.
Manually edit in the Current Tag Field Definition box and change the #isCustom# to #__Size_4#. There are two underscores in front of size and one after.
For me this appears to work for Universal Columns.
It appears that at least for the first 10 items in the Series list you can change the suffix on the __Size_ part of the tag with the number that matches the sort order of the Series list. I.E. AISC (Inch) is 1, BSI (Universal Beams) is 3, BSI (Universal Columns) is 4, etc.
I don't know of a way to get a single tag to display the correct information for different Series.
HTH.
