Steve Riddle Posted May 26, 2020 Share Posted May 26, 2020 I am having trouble with plant paths in a file using create object from shape command (plant from polyline in this instance). I am using polyline polyline to create a curved hedge row. Is there a way to edit the hedge row with a bezier path? This would be much easier than having to edit the polyline and re-convert to a plant. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted May 26, 2020 Vectorworks, Inc Employee Share Posted May 26, 2020 Hi Steve Yes, if the Plant is based on a polyline (in other words, you converted it with Poly-vertex mode active in the Plant tool, then you have two options: Double-click the plant and choose to edit the Path - this actually activates the Reshape tool, and you can then reshape the polyline as you wish. When you exit this edit mode (but orange button, top-right of the edit window), the Plant will regenerate. Simply click the Reshape tool, and then click on the Plant. Reshape as desired. The Plant will regenerate. 2 Quote Link to comment
