Fit Circle between Circles
I'm sure there is a better and indeed more accurate way.
But I create a line (center mode) at a tangent from the edge of the each circle. Then I use the circle tool in the 4th mode (Circle from 3 lines mode) and select the three lines and choose the appropriate side to place the circle object.
2065694041_Screenshot2020-05-25at17_52_41.thumb.png.70b5d994d58f29b7527f264ec862110a.png
Edited by markdd
On 5/25/2020 at 9:12 AM, Peter Z said:
Hi, beginner question, can I fit a circle between three circles? I'm having a blackout here
There is a Marionette network created by @DomC which does exactly what you're asking, available at THIS LINK.
Download and open the file named 'Geometry Nodes and PCC CCC.vwx; Look for the network at the far right side with the 'Apollonious PCC CCC v1' node. Click on that 'Apollonious' node, and then on the OIP under the 'Solution' pull-down select "-  -  -". Then click Run.
You'll have to modify the circles in the group to whatever size and configuration you want.
HTH.
1839357840_ScreenShot2020-05-26at2_02_58PM.thumb.jpg.19a55098421d1490040697bf6f3acb0d.jpg
