The Hamma Posted May 25, 2020 Share Posted May 25, 2020 (edited) """ This script identifies the name of a texture in the drawing and creates a new class with identified texture assigned to the newly created class. This is useful so that objects can be textured by assigning them to the appropriate class. This Python Script may be freely distributed. No warranty provided. Use at your own risk. If the name of the texture and the prefix exceeds 63 characters the class name will be shortened to 63 characters. This is a Vectorworks class name limitation. David Hamer, 2020 """ ClassPrefix ='I-FNSH-' #Newly created classes prefix TextureList, NumItems = vs.BuildResourceList(97, 0, '') while NumItems != 0: TextureName = vs.GetNameFromResourceList(TextureList, NumItems) TextureClassNameW = vs.Concat(ClassPrefix,TextureName) TextureClassName = vs.Copy(TextureClassNameW, 1, 63) vs.NameClass(TextureClassName) vs.SetClFillFore(TextureClassName,0,0,0) vs.SetClFillBack(TextureClassName,0,0,0) vs.SetClPenFore(TextureClassName,65535,65535,65535) vs.SetClPenBack(TextureClassName,65535,65535,65535) vs.SetClFPat(TextureClassName,1) vs.SetClLSN(TextureClassName,2) vs.SetClLW(TextureClassName,10) vs.EnableCLDropShadow(TextureClassName,False) vs.SetClUseGraphic(TextureClassName,True) TextureIndex = vs.Name2Index(TextureName) vs.SetClTextureC(TextureClassName, TextureIndex) vs.SetClTextureD(TextureClassName, TextureIndex) vs.SetClTextureG(TextureClassName, TextureIndex) vs.SetClTextureL(TextureClassName, TextureIndex) vs.SetClTextureR(TextureClassName, TextureIndex) vs.SetClTextureT(TextureClassName, TextureIndex) vs.SetClUseTexture(TextureClassName, True) NumItems = NumItems -1 Edited May 25, 2020 by The Hamma Quote Link to comment
Boh Posted July 31, 2020 Share Posted July 31, 2020 Hey @The Hamma this is a nice script that I've finally got around to checking out. Could be really usefully when experimenting with different textures. Are you using it in your workflow? Would it be useful iof the script also placed the selected object in the newly created class as well as made the object's take on the class texture? Thanks for sharing it. Quote Link to comment
The Hamma Posted July 31, 2020 Author Share Posted July 31, 2020 (edited) The script creates several classes at once and would not know which class to assign the selected object to. I will think about it and if any ideas come to mind I will script them down. On another note the script above would change the settings of previously created classes created by this script when running it a second time. I have modified the script to only create a new class if it does not exist and to give you a list of all the newly created classes when it is finished. """ This script identifies the name of a texture in the drawing and creates a new class with identified texture assigned to the newly created class. This is useful so that objects can be textured by assigning them to the appropriate class. This Python Script may be freely distributed. No warranty provided. Use at your own risk. If the name of the texture and the prefix exceeds 63 characters the class name will be shortened to 63 characters. This is a Vectorworks class name limitation. David Hamer, 2020 Revised 2020-07-31 """ ClassPrefix ='I-FNSH-' #Newly created classes prefix runtimes = 0 TextureList, NumItems = vs.BuildResourceList(97, 0, '') while NumItems != 0: TextureName = vs.GetNameFromResourceList(TextureList, NumItems) TextureClassNameW = vs.Concat(ClassPrefix,TextureName) TextureClassName = vs.Copy(TextureClassNameW, 1, 63) ClassCount = vs.ClassNum() # determine number of classes in drawing vs.NameClass(TextureClassName) if ClassCount + 1 == vs.ClassNum(): runtimes = runtimes + 1 if runtimes == 1: allclasses = TextureClassName else: allclasses = vs.Concat(allclasses, ', ', TextureClassName) vs.SetClFillFore(TextureClassName,0,0,0) vs.SetClFillBack(TextureClassName,0,0,0) vs.SetClPenFore(TextureClassName,65535,65535,65535) vs.SetClPenBack(TextureClassName,65535,65535,65535) vs.SetClFPat(TextureClassName,1) vs.SetClLSN(TextureClassName,2) vs.SetClLW(TextureClassName,10) vs.EnableCLDropShadow(TextureClassName,False) vs.SetClUseGraphic(TextureClassName,True) TextureIndex = vs.Name2Index(TextureName) vs.SetClTextureC(TextureClassName, TextureIndex) vs.SetClTextureD(TextureClassName, TextureIndex) vs.SetClTextureG(TextureClassName, TextureIndex) vs.SetClTextureL(TextureClassName, TextureIndex) vs.SetClTextureR(TextureClassName, TextureIndex) vs.SetClTextureT(TextureClassName, TextureIndex) vs.SetClUseTexture(TextureClassName, True) NumItems = NumItems -1 if runtimes != 0: vs.AlrtDialog('New Classes Created: ', allclasses) else: vs.AlrtDialog('No new Classes created') Edited July 31, 2020 by The Hamma Quote Link to comment
