jeff prince Posted June 19, 2020 Author Share Posted June 19, 2020 This is such a vexing problem, I had to run through some more experiments before retiring for the night. All of my effort had been around creating image props, so I started there. I then decided to make a new Plant Object using the same texture I had been using all along, only having VWX make the imageprop as part of defining the new plant. This yielded a successful result, though it does not solve the greater problem I identified earlier in this thread with regards to how VWX exports alpha channels applied to 3D model textures and standard user created image props. I have no idea of what is going on under the hood, but maybe there is an explanation that can be offered? Still, the 3D model issue is unresolved, so I hope to hear something on that @Dave Donley when you have a chance. 2 1 Quote Link to comment
mjm Posted June 21, 2020 Share Posted June 21, 2020 On 6/18/2020 at 2:01 PM, jeff prince said: Hacked VWX plant texture @jeff prince I hate to say it, but at least there's a relatively simple, however tedious and seemingly unnecessary, workaround. Thanks for the grunt work to uncover it. 2 Quote Link to comment
jeff prince Posted June 29, 2020 Author Share Posted June 29, 2020 @Dave Donley any advice or updates? 1 Quote Link to comment
jeff prince Posted July 15, 2020 Author Share Posted July 15, 2020 @Dave Donley any advice or updates? 1 Quote Link to comment
jeff prince Posted July 17, 2020 Author Share Posted July 17, 2020 Nifty... VB Basic plants have the same issue if you decide to export via C4D and import into Twinmotion... Quote Link to comment
jeff prince Posted July 28, 2020 Author Share Posted July 28, 2020 Over 2 months have passed since I posted this thread. Still, no solution. Vectorworks Tech Support emailed me last week in response to submitting a help request... still waiting to hear back. Really compelling marketing strategy... Quote Link to comment
JazzLX Posted June 17, 2021 Share Posted June 17, 2021 Hey, This was a year ago, you've probably nailed this by now... but if not maybe this is helpful? https://twinmotionhelp.epicgames.com/s/question/0D52L00003bNsLISA0/hi-i-am-trying-to-apply-a-alpha-transparency-map-to-a-leaf-material-but-only-get-the-attached-result-i-have-checked-the-opacity-setting-in-twinmotion-but-still-dont-get-the-transparency-any-help-appreciated?language=en_US I'm trying to find a youtube video I saw on this..... Pretty sure it's a Twinmotion quirk rather than a VW quirk, although the direct export to datasmith seems to be pretty good on the projects I've been playing with. Apart from the glass... but that's probably me! 1 Quote Link to comment
Lunar Waneshaft Posted June 17, 2021 Share Posted June 17, 2021 Also, as backward as it sounds, grab objects / materials / textures from Quixel Bridge, and bring them into VW. I'm really hoping that VW partners with Quixel, so we can use the same assets from start (VW) to finish (TM). Redshift has already done this, and they're part of the same software family so it's not that far of a stretch. 1 Quote Link to comment
jeff prince Posted June 17, 2021 Author Share Posted June 17, 2021 (edited) 34 minutes ago, JazzLX said: This was a year ago, you've probably nailed this by now... but if not maybe this is helpful? You would think this would have been resolved by now, but it hasn’t... Edited June 17, 2021 by jeff prince Quote Link to comment
JazzLX Posted June 18, 2021 Share Posted June 18, 2021 Twinmotion doesn’t understand the opacity map, the black and white image used to create the transparency, in VW. I also believe that quite a few of the shaders that can be used when creating textures are specific to Renderworks and don’t export out, hence the reason some textures come out looking different. So if textures made by VW in the resource browser use these, they also won’t export out the shaders. It’s quite easily fixed in Twinmotion with no issues, this guys vid is quite good, though I’m sure I saw another one somewhere but can’t find it right now. I don’t think there is anything to fix. The two programs just work differently for transparency as far as I can tell…. Quote Link to comment
jeff prince Posted June 18, 2021 Author Share Posted June 18, 2021 @JazzLX appreciate your interest in the problem, but that's not the issue. Your video shows how to make a PNG with a transparent background. I already have those, 1000s of those and do not use the black and white opacity map 🙂 Twin Motion is not using the black and white opacity map either, you can delete them from the C4D export and it has no effect on the Twinmotion import. The problem is Vectorworks is adding a black background to my carefully crafted PNG textures during the export via C4D. Interestingly enough, Vectorworks does not vandalize the textures that shipped with the software, just user created ones, even when they are built exactly the same as the stock textures. Perhaps the software is just being vindictive for having the audacity to use my own textures? I did post a laborious work around in this thread, but I have yet to hear a reason why Vectorworks treats user textures differently than default textures provided with the software. Any ideas on that? Quote Link to comment
JazzLX Posted June 18, 2021 Share Posted June 18, 2021 I don't think that VW has turned into Skynet just yet.... maybe in future updates? Perhaps, rather than it being the export that is screwing with the textures, it is the way it imports and sees the alpha, converting it to the black/white opacity map for use within software, therefore that's what it exports? I highly doubt that VW differentitates between user textures and shipped textures, so they must not be built in exactly the same way, probably something under the hood somewhere. It clearly isn't just the VW import into Twinmotion, as there are quite a few videos dealing with the issue in Twinmotion. Out of curiousity, have you tried using the direct export to datasmith function? Maybe it's fixed there...? Quote Link to comment
jeff prince Posted June 18, 2021 Author Share Posted June 18, 2021 4 hours ago, JazzLX said: I don't think that VW has turned into Skynet just yet.... maybe in future updates? Perhaps, rather than it being the export that is screwing with the textures, it is the way it imports and sees the alpha, converting it to the black/white opacity map for use within software, therefore that's what it exports? I highly doubt that VW differentitates between user textures and shipped textures, so they must not be built in exactly the same way, probably something under the hood somewhere. It clearly isn't just the VW import into Twinmotion, as there are quite a few videos dealing with the issue in Twinmotion. Out of curiousity, have you tried using the direct export to datasmith function? Maybe it's fixed there...? Based on your responses, its clear you have not gone thru the exercise of exploring this specific issue. It’s not a twin motion issues, it is a Vectorworks problem with how it exports. Datasmith and videos on the internet don’t fix it either. 2 Quote Link to comment
jeff prince Posted September 30, 2022 Author Share Posted September 30, 2022 @Dave Donley any updates on how to address this issue? Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted September 30, 2022 Vectorworks, Inc Employee Share Posted September 30, 2022 Hi @jeff prince I used the Datasmith Direct Link tool in Vectorworks 2023 with the original file and it is exporting well using Datasmith. If you still want to use export to C4D and then open C4D in Twinmotion I believe you will still have the problem you described. Datasmith Direct Link tool would be the recommended way to get your models into Twinmotion these days. 2 Quote Link to comment
jeff prince Posted September 30, 2022 Author Share Posted September 30, 2022 1 hour ago, Dave Donley said: Hi @jeff prince I used the Datasmith Direct Link tool in Vectorworks 2023 with the original file and it is exporting well using Datasmith. If you still want to use export to C4D and then open C4D in Twinmotion I believe you will still have the problem you described. Datasmith Direct Link tool would be the recommended way to get your models into Twinmotion these days. Thanks for the reply @Dave Donley. I'll give it a try and see what happens. Perhaps something has been updated in the last year.... Quote Link to comment
